HI
Umbraco version 4.11.8
The problem:I cant login to the backend it gives me this error ERROR Umbraco.Web.UmbracoApplication
I prity sure it is relatede to the issue "Path Fixup".
I had run the "Path Fixup" for a long tim ago, and yesterday i was moving some nodes and unpublishing some nodes.
I was not aware off the issue, that i should had been runing the "Path Fixup" every time i move or copy nodes.
Now i cant login to the backend, and of cource i can´t run the path fix.
Hope someone have a solition for this.
René
It was the issue with the empty application.config and the three.config in the config folder.
I downloaded a new instance of the umbraco version and copied the application.config and the three.config in to the config folder.
If this can help any one i found the answer here: http://our.umbraco.org/forum/core/general/38056-Emtpy-applications-and-trees-config-files
Upload image
ERROR Umbraco.Web.UmbracoApplication Path Fixup
HI
The problem:
René
HI
René
