Umbraco.Web.PublishedCache.XmlPublishedCache.XmlPublishedProperty error after upgrade
I've upgraded an Umbraco 6.1.6 site to 6.2.5 and most of the site is fine afterwards but I've had a couple of issues.
I have a media type that has a textbox multiple property called slideCaptionOne. After the upgrade rather than showing the text entered all that is output is Umbraco.Web.PublishedCache.XmlPublishedCache.XmlPublishedProperty.
We're using the following code which worked fine before the upgrade:
@slide.GetProperty("slideCaptionOne")
Slide is created here:
@foreach (var x in (Umbraco.Core.Dynamics.DynamicXml)Model.Content.GetPropertyValue("slides")) { var slide = Umbraco.TypedMedia(x.InnerText);
@slide.GetProperty("slideCaptionOne")Slide is created here:
@foreach (var x in (Umbraco.Core.Dynamics.DynamicXml)Model.Content.GetPropertyValue("slides")){
Other properties on this type work fine.
@Html.Raw(@slide.GetPropertyValue("slideCaptionOne")) Seems to do the trick
