Could not load types from assembly Create.Plugin.ApproveIt, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null, errors:
I tried to install the Approve It plugin, but received this error even when deleting the plugin files in App_Plugins.
Any suggestions?
Thanks so much,
Amanda
Exception: System.IO.FileLoadException: Could not load file or assembly 'System.Net.Http.Formatting, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
File name: 'System.Net.Http.Formatting, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Exception Details: System.Reflection.ReflectionTypeLoadException: Could not load types from assembly Create.Plugin.ApproveIt, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null, errors:
Source Error:
Stack Trace:
[ReflectionTypeLoadException: Could not load types from assembly Create.Plugin.ApproveIt, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null, errors:
[HttpException (0x80004005): Could not load types from assembly Create.Plugin.ApproveIt, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null, errors:
What version of Umbraco are you using? It looks like ApproveIt is expecting a version of the assembly System.Net.Http.Formatting that is not present in your installation.
Any suggestions?
Thanks so much,
Amanda
Could not load types from assembly Create.Plugin.ApproveIt, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null, errors: Exception: System.IO.FileLoadException: Could not load file or assembly 'System.Net.Http.Formatting, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'System.Net.Http.Formatting, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Exception Details: System.Reflection.ReflectionTypeLoadException: Could not load types from assembly Create.Plugin.ApproveIt, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null, errors: Exception: System.IO.FileLoadException: Could not load file or assembly 'System.Net.Http.Formatting, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'System.Net.Http.Formatting, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
Source Error:
Stack Trace:
[ReflectionTypeLoadException: Could not load types from assembly Create.Plugin.ApproveIt, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null, errors: Exception: System.IO.FileLoadException: Could not load file or assembly 'System.Net.Http.Formatting, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'System.Net.Http.Formatting, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
] Umbraco.Core.TypeFinder.GetTypesWithFormattedException(Assembly a) +382 Umbraco.Core.TypeFinder.GetClasses(Type assignTypeFrom, IEnumerable
1 assemblies, Boolean onlyConcreteClasses, Func2 additionalFilter) +353 Umbraco.Core.TypeFinder.FindClassesOfType(IEnumerable1 assemblies, Boolean onlyConcreteClasses) +62 Umbraco.Core.TypeFinder.FindClassesOfType(IEnumerable1 assemblies) +45 Umbraco.Core.<>c_DisplayClass411.<ResolveTypes>b__40() +60 Umbraco.Core.PluginManager.LoadViaScanningAndUpdateCacheFile(TypeList typeList, TypeResolutionKind resolutionKind, Func1 finder) +46 Umbraco.Core.PluginManager.ResolveTypes(Func1 finder, TypeResolutionKind resolutionType, Boolean cacheResult) +2254 Umbraco.Core.PluginManager.ResolveTypes(Boolean cacheResult, IEnumerable1 specificAssemblies) +149 Umbraco.Core.CoreBootManager.InitializeApplicationEventsResolver() +46 Umbraco.Web.WebBootManager.InitializeApplicationEventsResolver() +5 Umbraco.Core.CoreBootManager.Initialize() +343 Umbraco.Web.WebBootManager.Initialize() +75 Umbraco.Core.UmbracoApplicationBase.StartApplication(Object sender, EventArgs e) +177 Umbraco.Core.UmbracoApplicationBase.ApplicationStart(Object sender, EventArgs e) +9[HttpException (0x80004005): Could not load types from assembly Create.Plugin.ApproveIt, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null, errors: Exception: System.IO.FileLoadException: Could not load file or assembly 'System.Net.Http.Formatting, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'System.Net.Http.Formatting, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
] System.Web.HttpApplicationFactory.EnsureAppStartCalledForIntegratedMode(HttpContext context, HttpApplication app) +9941581 System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers) +118 System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context) +172 System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +339 System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +296
] System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +9923092 System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +90 System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +261
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.6.114.0
Hi Amanda,
André Santos
Hi André,
Thanks for such a quick reply!
It looks like I'm using 7.2.8.
I will update my installation of Umbraco and then try again.
Thanks for your help.
-Amanda
Hi Amanda,
Did it work?
Hi André,
I apologize for the late response. I did finally upgrade from 7.2.8 to 7.3.4.
ApproveIt is now working.
Thanks so much,
Amanda
Nice to see you got it working. I'm going to look into this anyway. Approve It shouldn't be dependent on the version of System.Net.Http.Formatting.
Thanks!
