  • Simon steed 378 posts 700 karma points
    Jul 25, 2012 @ 13:51
    Simon steed
    Nice work
    Hi Nigel
    Not many comments here so thought i'd say H5YR for this, very useful package and exactly what one of my clients needed.
    Only change i've had to make is to make the default 500px wide help tab a little larger so it's more readable.
    Thanks for releasing it
    Si
  • Nigel Wilson 945 posts 2077 karma points
    Jul 25, 2012 @ 19:47
    Nigel Wilson
    Hi Si
    Thanks for the feedback - I appreciate it and it's nice to hear that it has proven useful for you.
    With regards
    Nige
    Jul 25, 2012 @ 20:40
    Simon steed
    No worries - is the source available, we ran into a problem resulting in having to remove from some doc types. Basically I had the datatype set to the Base Doc Type which worked great for the homepage but we noticed when we created a page, we got a YSOD - this happened on a standard textpage so I removed from base, added to the homepage which then allowed us to create the std page
    Not sure yet what is going on but will reproduce locally tomm so I can get the error, source would be handy so I can fix as client loves it now :-)
    Jul 25, 2012 @ 21:38
    Nigel Wilson
    Hi Simon
    No problems providing the source code - I am at work now so will get it sorted over the next day or so.
    Be great to update the source / package if you are able to advise of any changes.
    Cheers
    Nige
    Jul 25, 2012 @ 23:10
    Simon steed
    Nice one, cheers - sure we can easily fix it, should be reproducable enough - our environment is a large multi site multi domain install so good testing ground.
    Sent a collab request too.
    Si
