  • ajit goel 6 posts 26 karma points
    Jan 28, 2014 @ 05:34
    ajit goel
    error when loading package
    get an error when trying to load the package
    • This package references the assembly 'System.Web.Extensions' which was not found
  • Fuji Kusaka 2203 posts 4220 karma points
    Jan 28, 2014 @ 09:32
    Fuji Kusaka
    What version of umbraco are you using and you need to check if the package is compatible with it.
    Not all packages are compatible with all version of umbraco.
