  • Richard Barg 358 posts 532 karma points
    Apr 03, 2013 @ 01:42
    Richard Barg
    Moving branches
    It would be great if you could move a branch within one part of a tree to another using right-click, the same as you do w/nodes in thne content and media areas.
  • James Patterson 53 posts 192 karma points
    Apr 03, 2013 @ 09:47
    James Patterson
    Great suggestion. I've added this to the list and should be in the release later this month.
    Apr 05, 2013 @ 17:57
    Richard Barg
    Thanks. Looking forward to it.
    Apr 07, 2013 @ 20:33
    Richard Barg
    James,
    For us anyway, this project holds great potential to simplify our workflow. Our progammer has already developed a change for the implementation of categories in the content area at my urging.  Users can select all of the children of a parent simply by checking the parent. Children can then be selectively unchecked. Or discrete children can be checked ad hoc. This is analagous to the selection of components of Microsoft desktop products during installation. We will be happy to share the code if this addition seems non-obvious to you.
    In the settings area, I am hoping we will be able to move individual nodes as well as individual branches. I will let you know if I think of anything else.
    Apr 07, 2013 @ 21:00
    James Patterson
    Great! I will implement this in the core package. I will make it optional though, being able to disable/enable the behaviour in the data type settings.
    Thanks.
    May 21, 2013 @ 03:52
    Richard Barg
    Any news on this front - in the settings.
    May 21, 2013 @ 08:19
    James Patterson
    Moving trees was one of the changes in the current release, auto-select of decendants hasn't yet been implemented. I'm aiming for a release over the next week or so - there are not enough hours in the day at the moment.
