  • Robert J. Bullock 386 posts 405 karma points
    Feb 11, 2013 @ 23:07
    Robert J. Bullock
    Work with Media Types?
    Can I add a field to a custom Media Type that uses categories? And can I retrieve the related items using your methods?
  • James Patterson 53 posts 192 karma points
    Feb 19, 2013 @ 17:03
    James Patterson
    Should work fine. If you're working with Node objects or working in XSLT then it should be fine. To get related items you will have to write something yourself but there's a dirty example of how it can be done in the samples project under 'source' on the package page.
    If there's something you think should be added to make what you want to do easier then let us know.
