There is now a few simple extension methods for using in Views. You'll need to upgrade to use version 2.5 of the package which does not support Umbraco v4.x.
Here are a few examples of each of the extension methods where 'categories' is the alias of the Category Selection property.
1. Get all categories assigned to the current page.
@foreach(var category in CurrentPage.GetCategories("categories"))
<li>@category.Name</li>
2. Get child pages of the current page which have the category with ID 1 assigned.
@foreach(var page in CurrentPage.GetChildrenByCategory("categories", 1))
<li>@page.Name</li>
3. Get descendants of the current page which have category with ID 2 assigned.
@foreach(var page in CurrentPage.GetDescendantsByCategory("categories", 2))
<li>@page.Name</li>
4. Get decendants of current page which have category with ID 2 assigned and the document type of 'umbTextpage'.
@foreach(var page in CurrentPage.GetDescendantsByCategory("categories", 2, "umbTextpage"))
<li>@page.Name</li>
5. Get all decendants of a known page which have category with ID 1 assigned.
@foreach(var page in Umbraco.TypedContent(1050).GetDescendantsByCategory("categories", 1))
<li>@page.Name</li>
I hope this helps.
As always, feel free to suggest additional functionality or improvements.
Ok, sorry, it's my fault, my property alias is "category" and I didn't update the snippet. Anyway, I installed 2.5.0 as a whole new section is an overkill, a tree node in Settings is sufficient. Examples work fine, thanks for great package!
Umbraco 6 Razor Usage
How do we use the categorisation package in Umbraco 6 with razor views? Bearing in mind we use IPublishedContent, not Node.
Hi Mark,
@foreach(var category in CurrentPage.GetCategories("categories")) { <li>@category.Name</li> }2. Get child pages of the current page which have the category with ID 1 assigned.
@foreach(var page in CurrentPage.GetChildrenByCategory("categories", 1)) { <li>@page.Name</li> }3. Get descendants of the current page which have category with ID 2 assigned.
@foreach(var page in CurrentPage.GetDescendantsByCategory("categories", 2)) { <li>@page.Name</li> }4. Get decendants of current page which have category with ID 2 assigned and the document type of 'umbTextpage'.
@foreach(var page in CurrentPage.GetDescendantsByCategory("categories", 2, "umbTextpage")) { <li>@page.Name</li> }5. Get all decendants of a known page which have category with ID 1 assigned.
@foreach(var page in Umbraco.TypedContent(1050).GetDescendantsByCategory("categories", 1)) { <li>@page.Name</li> }I hope this helps.
James
Hi James,
I've just installed v2.5.1, created a couple of categories and assigned them using Category Picker. None of the examples above seem to work.
Was something changed?
