Hi everyone, I am using Umbraco 6.2.5 and Categorisation 2.5.1.0.
The problem I am having is that when I try to move an item to another folder, the "move button" is not activa, so I cannot (it doesn't matter what node I click on the tree) move the item so the father is differente.
To be able to move an item to another folder, you need to allow the the item to be created in to the folder. So first of all go the the settings section --> Document types --> find the document type for the folder where you will allow the item to be able to be create under.
Then take the structure tab, and set tick in the page that should be able to live under the folder. Then you can move the item under the folder.
Okay then I think I will move the question to the forum for this package. I think then there is a bigger change that the creator of the page would see thatyou have a question.
Move categorisation item between folders
Anyone knows how to fix this?
Thank you very much!!
Adriana.
Hi Adriana and welcome to our :-)
Try to see this videos about allow child-nodetypes http://umbraco.tv/videos/umbraco-v7/implementor/fundamentals/document-types/allowed-child-nodetypes/
DonĀ“t be confused that the Ul looks different, this is how the UI looks in Umbraco 7, but you need to do the same in Umbraco.
Hope this helps and make sense to you
/Dennis
Hi Dennis, thank you so much for answering and welcoming me to te community =).
Unfortunatelyl in this case is not a problem of Doctype since the item that I am trying to move is in the "Categories" section in Umbraco.
Categories is the package that allows you to categorise the content in the general tree of Umbraco https://our.umbraco.org/projects/backoffice-extensions/categorisation-for-umbraco
Adri.
Hi Adriana,
/Dennis
Anyone? Plase =D
