Just with basic value settings, it seems that if I click [Save and Publish] without changing the selection in the document, the output is duplicated. If I edit the value, then save, there's no issue.
The issue is only if there's been no changes to the element and it's [Save and Publish] - duplicating each time.
Yes! I'm having trouble with this as well. For me, the following will cause an error:
Enter values into the property
Publish the page
Stay on the page in Umbraco and make an edit to the property (even empty it)
Publish the page
The value becomes duplicated for each publish. Interestingly enough, if you navigate away from that page in the back end, then return - the property reverts to an old value.
Values get duplicated
Just with basic value settings, it seems that if I click [Save and Publish] without changing the selection in the document, the output is duplicated. If I edit the value, then save, there's no issue. The issue is only if there's been no changes to the element and it's [Save and Publish] - duplicating each time.
Anyone else had this issue? I'm on 7.1.4
Umbraco 7.2.4
