  • Trevor Loader 199 posts 256 karma points
    Mar 01, 2017 @ 16:19
    Trevor Loader
    Compatibility Issues
    Hi David,
    Firstly, great control!
    Just wondering if you have plans to address any compatibility issues with the later versions of Umbraco as it doesn't appear to quite work properly?
    Either that, or any chance of making your source public so I can try and fix it?
    Thanks Trevor
  • David Zweben 268 posts 754 karma points
    Mar 02, 2017 @ 13:24
    David Zweben
    Hi Trevor,
    Thanks, I'm glad you like it. I don't have immediate plans to update it, but by their nature, Umbraco property editors are open source, as the Angular source code can be viewed in the downloaded package, so feel free to update it as you see fit.
    Regards, David
    Mar 02, 2017 @ 21:20
    Trevor Loader
    Ahh of course it is. Thanks.
  • Hendy Racher 863 posts 3849 karma points MVP 2x admin c-trib
    Mar 02, 2017 @ 13:31
    Hendy Racher
    Just to say, as an alternative, the nuPicker TypeaheadList Picker looks to offer similar functionality...
    Trevor Loader
    That might work equally as well too. Thanks Hendy!
