  • Petr Snobelt 923 posts 1535 karma points
    Mar 28, 2010 @ 13:55
    Petr Snobelt
    2
    Using in media section
    Hi Chris,
    will be great if it is possible to use it in media section, is there any chance to ise it there?
    Petr
    Mar 28, 2010 @ 16:49
    Morten Bock
    5
    I guess you could just go to settings -> media types and change the datatype used to this one?
  • Chris Koiak 700 posts 2626 karma points
    Mar 28, 2010 @ 18:13
    Chris Koiak
    2
    Absolutely correct Morten,
    This data type can be used inplace of the standard 'Upload' control. The location files are stored and the xml that's saved is identical to the Upload control.
    Chris
    Mar 29, 2010 @ 08:40
    Petr Snobelt
    Thanks, it's great.
    And what about possibility to choose and upload multiple filesinto folder?
    Petr
    Mar 29, 2010 @ 13:53
    Chris Koiak
    This datatype is focussed on single files and direct compatibility with the current 'Upload' datatype.
    Maybe I'll build a separate package for multiple file uploads, but theres already one available http://our.umbraco.org/projects/multiple-file-upload.
  • Casey Neehouse 1339 posts 483 karma points MVP 2x admin
    May 27, 2010 @ 20:23
    Casey Neehouse
    Chris,
    Replacing the default upload with this is a great idea, however, it does not allow the files to be linked in the rich text editor.  Simply, umbraco does not recognize your data type as a "LinkableMediaDataType".  You need to register the GUID into this List so that the link dialogs in tiny will work.
    Case
