Thanks for reporting the issue.
Which version of Umbraco are you running?
I see the issue in Umbraco v 7.4.x .. but not in v. 7.2.x and 7.3.x ..
Not sure when it has been broken - I think it is because some restrictions to the upload made in Umbraco, which may affect the fileupload I use in my package to import/export palettes.
<!-- These file types will not be allowed to be uploaded via the upload control for media and content -->
<disallowedUploadFiles>ashx,aspx,ascx,config,cshtml,vbhtml,asmx,air,axd,swf,xml,html,htm,svg,php,htaccess</disallowedUploadFiles>
It is a bit strange it add "!" in front of each file extension...
In the directive in Color Palettes in allow .json and .txt upload:
You are right, it is added in the umbraco.controller.js two places
//instead of passing in a whitelist, we pass in a blacklist by adding ! to the ext
vm.acceptedFileTypes = mediaHelper.formatFileTypes(Umbraco.Sys.ServerVariables.umbracoSettings.disallowedUploadFiles).replace(/./g, "!.");
Breaks Media drag and drop
After installing Color Palettes the drag and drop in media breaks, and every upload gives this error:
Could it be your use of accept variable that angular also uses for the upload.
Uninstalling Color Palettes fixes problem.
Hi Nicolai
Thanks for reporting the issue. Which version of Umbraco are you running?
I see the issue in Umbraco v 7.4.x .. but not in v. 7.2.x and 7.3.x .. Not sure when it has been broken - I think it is because some restrictions to the upload made in Umbraco, which may affect the fileupload I use in my package to import/export palettes.
But I noticed it seems Umbraco use same Angular upload directive, so it might be the reason why it now has some issues. https://github.com/umbraco/Umbraco-CMS/blob/24f38e0c0e73e0246fd7cff1ffb77bc001d56069/src/Umbraco.Web.UI.Client/src/views/components/upload/umb-file-dropzone.html
I will take a look at it..
/Bjarne
Hi Bjarne,
I think you are right. I have tested it on 7.4.1 and latest.
I also got the following error in v.7.4.0
In v. 7.2.2 however I get this error when I upload some images:
It seems to match the restricted files: https://our.umbraco.org/forum/core/general/57850-Restricting-file-types-that-can-be-uploaded-to-the-back-office-media-section
In the config the files are with ! in front, you think it will fix it to remove it?
No, the config files just list the files like this:
but I don't know why it add "!" in front of each file extension in the error message.
It doesn't seems to make a difference whether I add "jpg" to the list or not.
Hi Nicolai
In Umbraco 7.4.x ng-file-upload is also included in core, so actually it is not needed to include it in my package. However with this fix for v. 7.4.3 it should work even with ng-file-upload included https://github.com/umbraco/Umbraco-CMS/commit/d8c781f97f344792b2d21936605f2045baa112cf
You can try with this build: https://ci.appveyor.com/project/Umbraco/umbraco-cms-hs8dx/build/3488/artifacts
But for Umbraco 7.4.0 - 7.4.2 it should work if you exclude ng-file-upload in package.manifest Just remove or uncomment this line:
Can you test if that works for you?
/Bjarne
Worked for me in 7.4.1 - Man, I was getting a lot of "why????" mails from the client :-)
/Chriztian
