Hi, I really like the Currency Input property editor but I'm running into one little issue. BTW I'm using Umbraco 7.4.1.
I can't seem to configure it to pad decimals to two places - values are padded to one decimal place.
For example, if "3" is entered, the value is padded to one decimal place like this: "3.0". I would like it to be padded like this: "3.00"
It is configured mostly with the defaults except for:
Currency Symbol: $
Padding: [checked]
Any help you can offer would be appreciated. Cheers, David
Not padding to two decimal places
Currency Symbol: $
Padding: [checked]
