Unfortunately DAMP is created as a loose datatype and can't be used in the RTE. A whole new package should be created for this that can interact with the RTE. This is currently not on the roadmap, but I will release the source code soon so you could try it for yourself :).
DAMP + RTE
first of all, thank you very much for this great package - really a must-have!
Would it be possible to use DAMP in RTE (instead of standard media picker) also?
Best Regards
Andreas
Hi Andreas,
Jeroen
