  • Robert Dolman 22 posts 42 karma points
    Oct 26, 2011 @ 14:34
    Robert Dolman
    A few feedback comments
    Firstly thanks for taking the time to develop this, it's a cracking solution to handling media.
    One thing that is a little annoying, if you right-click in the list selection on the left you get an empty menu with a single blank menu item, which also causes an odd rendering bug in IE which knocks the inner container out of alignment & causes the vertical scrollbar to show.
    Also, single-clicking in the blank area to the right of a folder causes it to collapse the folder node. This then requires a double-click on the folder text (or icon) to re-expand the node. This is a bit strange to me.
    Other than that it works like a charm!
    Oct 26, 2011 @ 14:40
    Jeroen Breuer
    Hello Robert,
    Thanks for the feedback. DAMP uses the default Umbraco tree and this is standard behavior. Is you use the Multi Node Tree Picker from uComponents you'll see the same happens. I don't think I can change this. My advice is not use the right-click =). It won't do anything.
    Jeroen
