  • Simon Dingley 1474 posts 3451 karma points c-trib
    Mar 17, 2012 @ 13:03
    Simon Dingley
    Null Reference Exception after install
    I'm a fan already of DAMP and have used it before however my recent installation keeps throwing the following exception:
       ASP.umbraco_plugins_digibizadvancedmediapicker_selectmediaitem_aspx.__RenderContentPage(HtmlTextWriter __w, Control parameterContainer) +84
       System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +109
       System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +8
       System.Web.UI.Control.Render(HtmlTextWriter writer) +10
       System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27
       System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100
       System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25
       System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +208
       System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +173
       System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) +31
       System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +53
       umbraco.presentation.urlRewriter.FormRewriterControlAdapter.Render(HtmlTextWriter writer) +49
       System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +8996699
       System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +40
       System.Web.UI.Page.Render(HtmlTextWriter writer) +29
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3060
    I'm sure I'm just overlooking something but can someone spot the obvious mistake?
    Mar 20, 2012 @ 08:51
    Simon Dingley
    The exception seems to be thrown during the instantiation of DigibizPickerView which is throwing an inner exception of "Sequence contains no elements".
    Will post more if I make any further progress!
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Mar 20, 2012 @ 09:20
    Jeroen Breuer
    I haven't seen this error before. I think it's best if you debug the source to see what might be the problem.
    Jeroen
    Mar 20, 2012 @ 09:59
    Simon Dingley
    That's what I'm trying to do but with little success at the moment. I've discovered the site is running 4.7.0 and so I am upgrading to 4.7.1 to see if that makes any difference.
    Thanks, Simon
    Mar 20, 2012 @ 10:06
    Simon Dingley
    And an upgrade to 4.7.1 doesn't seem to help at all either. I'm going to have to fall back to a standard Media Picker for now as I need to get this change out. Hopefully I will have time to return to this at a later date.
    Apr 02, 2012 @ 17:56
    Jeroen Breuer
    Did you find out what the problem was?
    Jeroen
    Apr 02, 2012 @ 18:03
    Simon Dingley
    Unfortunately due to time and current workload I have not had a chance to return to this yet and had to take the easy option and leave DAMP out for now I'm afraid.
