  • John Hodgkinson 613 posts 355 karma points
    Aug 16, 2012 @ 19:59
    John Hodgkinson
    any known compatibility issues with umbraco 4.8.1?
    many thanks!
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Aug 22, 2012 @ 09:44
    Jeroen Breuer
    I haven't tested it yet, but it has been reported to be compatible with 4.8.0 so it probably also works on 4.8.1.
    Jeroen
    Sep 16, 2012 @ 12:47
    Anthony Candaele
    I seem to have a problem with the DAMP_Helper.GetImageCropperUrl() method in Umbraco 4.9.0:
    this code genereates an error:
    var solutionCrop = DAMP_Helper.GetImageCropperUrl(product.solutionImage, "solutionCrop");
                 <img src="@solutionCrop"/>
    anyone else encountered problems with DAMP in Umbraco 4.9.0?
    greetings,
    Anthony
    Sep 16, 2012 @ 14:20
    Anthony Candaele
    ok, my bad, problem was that product was of type DynamicNode, after changing the type to dynamic the GetImageCropperUrl method works just fine.
    greetings,
    Anthony
