  • Patrick 23 posts 83 karma points
    Oct 15, 2012 @ 21:15
    Patrick
    4.9 MySQL installation problem
    I'm installing Damp in Umbraco 4.9 using a MySQL database.
    The installation runs normal, withou any error messages, however the Damp data type doesn't appear in the tree.
    Is it possible Damp doesn't work with MySQL? Or is there another issue why the install doesn't seem to complete properly? Damp is mentioned in the list of installed packages, so something seems to go as expected.
    Anybody got a clue about a solution?
    Greetings, Patrick
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Oct 15, 2012 @ 21:45
    Jeroen Breuer
    DAMP 2.0 doesn't add any datatypes by itself. If you create a new datatype you can probably choose the Digibiz Advanced Media Picker as a render control.
    If you want to have a datatype to use as an example you can use the DAMP 2.0 Samples package. You can watch a video on how to install it here: http://www.screenr.com/gz0s.
    Jeroen
    Oct 16, 2012 @ 20:21
    Patrick
    Thanks Jeroen,
    Previously I used the examples, this time I wanted a blank install to be sure it worked on MySQL isntead of MSSQL.
    Overlooked it, thanks for your reply!
    Patrick
