  • Kenny Burns 173 posts 305 karma points
    Nov 22, 2012 @ 12:43
    Kenny Burns
    4.10.1 Issue
    I installed DAMP (used it before on earlier versions - great package Jeroen!) on a 4.10.1 version. The package seemed to install fine and had no problems but when i went into a doctype i got an error (see below)
    It wont allow me to click on any doctypes (i havent created a datatype yet with DAMP) - if I uninstall DAMP then the doctypes are fine again.
    Kenny
    An unhandled exception occurred
    System.Web.HttpUnhandledException (0x80004005): Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.NullReferenceException: Object reference not set to an instance of an object.
       at umbraco.controls.ContentTypeControlNew.setupInfoPane()
       at umbraco.controls.ContentTypeControlNew.OnInit(EventArgs e)
       at System.Web.UI.Control.InitRecursive(Control namingContainer)
       at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
       at System.Web.UI.Page.HandleError(Exception e)
       at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
       at System.Web.UI.Page.ProcessRequest()
       at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context)
       at System.Web.UI.Page.ProcessRequest(HttpContext context)
       at ASP.umbraco_settings_editnodetypenew_aspx.ProcessRequest(HttpContext context) in c:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\38e8e59b\5bedb3e0\App_Web_editnodetypenew.aspx.a5729980.qulqqmwg.0.cs:line 0
       at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
       at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
    Nov 23, 2012 @ 16:09
    Kenny Burns
    Update:
    An upgrade to Umbraco 4.11 fixed this issue. Maybe a bug/clash somewhere?
    Anyways, it's now fixed. Happy days! :)
    Kenny
