  • Joe 7 posts 27 karma points
    Jul 02, 2013 @ 13:26
    Joe
    DAMP - Load images
    I have a problem for lod several images with DAMP.
    try
        <div id="slider" style="padding-left: 12px">
           <div id="ei-slider" class="ei-slider">
              <ul class="ei-slider-large">
                 @foreach (var list in Model.AncestorOrSelf(1).Descendants("ResultatsItem"))
                   foreach (var item in Model.photosDuMatch)
                        var image = Model.NodeById(list.photosDuMatch);
                        <li>
                             <img src="@image.Url" alt=""/>
                         </li>
                </ul>
                <ul class="ei-slider-thumbs">
                   <li class="ei-slider-element">Current</li>
                          <li><a href="#">Slide 6</a><img src="@image.Url" alt="" /></li>
                  </ul><!-- ei-slider-thumbs -->
                <span class="shadowflat"><img src="/images/big-shadow3.png" alt="" /></span>
     catch
    This code work with one image but not work with two images. Thx.
    Jul 02, 2013 @ 15:19
    Jeroen Breuer
    Why are you doing a foreach inside a foreach? Do you store the data as xml or id? It might be a good idea to have a look at these examples:
    DAMP 2.5 Samples: Video - http://www.screenr.com/gz0s
    DAMP Gallery: Video - http://www.screenr.com/1Vx7
    Jeroen
    Jul 02, 2013 @ 15:29
    Joe
    I viewed videos but it does not say to me why my code is bad.
    And I have to remove the foreach second.
    Jul 02, 2013 @ 15:36
    Jeroen Breuer
    Could you please post a part of your umbraco.config xml file so I can see how you store the DAMP data. Please make sure it's stored as full xml on the datatype.
    Jeroen
    Jul 02, 2013 @ 15:39
    Joe
    <ResultatsItem id="1303" parentID="1302" level="3" creatorID="0" sortOrder="0" createDate="2013-07-01T13:25:54" updateDate="2013-07-02T13:39:06" nodeName="Equipe A" urlName="equipe-a" path="-1,1076,1302,1303" isDoc="" nodeType="1300" creatorName="admin" writerName="admin" writerID="0" template="1301">
            <umbracoUrlName />
            <umbracoUrlAlias />
            <umbracoRedirect />
            <umbracoNaviHide>0</umbracoNaviHide>
            <metaDescription><![CDATA[]]></metaDescription>
            <metaKeywords><![CDATA[]]></metaKeywords>
            <score>SC *** 2-1 ***</score>
            <resume><![CDATA[<div class="description">
    <p></p>
    </div>]]></resume>
            <date>Dim. 23 Juin 13 - 15h00</date>
            <journee>*** - 22ème journée</journee>
            <photosDuMatch>1216</photosDuMatch>
            <calendrier>http://www.fff.fr/la-vie-des-clubs/***/calendrier/***-a-venir/283517</calendrier>
            <classement>http://www.fff.fr/la-vie-des-clubs/***/page-classement/***-283517/phase-1/groupe-1</classement>
          </ResultatsItem>
    Jul 02, 2013 @ 15:46
    Jeroen Breuer
    Could you store the data as full xml? You need to change it in the datatype and save the page again. The xml should look different after that.
    Jeroen
    Jul 02, 2013 @ 16:02
    Joe
    <ResultatsItem id="1303" parentID="1302" level="3" creatorID="0" sortOrder="0" createDate="2013-07-01T13:25:54" updateDate="2013-07-02T16:13:56" nodeName="Equipe A" urlName="equipe-a" path="-1,1076,1302,1303" isDoc="" nodeType="1300" creatorName="admin" writerName="admin" writerID="0" template="1301">
            <umbracoUrlName />
            <umbracoUrlAlias />
            <umbracoRedirect />
    <p></p>
    </div>]]></resume>
            <photosDuMatch><![CDATA[<DAMP fullMedia="">
      <mediaItem>
        <Image id="1216" version="f25e385f-7a2d-4203-a6d9-68a82a4d60f2" parentID="1288" level="4" writerID="0" nodeType="1032" template="0" sortOrder="0" createDate="2013-06-24T13:10:52" updateDate="2013-06-25T14:58:33" nodeName="Parcdessports" urlName="parcdessports" writerName="admin" nodeTypeAlias="Image" path="-1,1164,1190,1288,1216">
          <umbracoFile>/media/860/parcdessports.jpg</umbracoFile>
          <umbracoWidth>2560</umbracoWidth>
          <umbracoHeight>1]]></photosDuMatch>
            <calendrier>http://www.fff.fr/la-vie-des-clubs/***/calendrier/liste-matchs-a-venir/283517</calendrier>
            <classement>http://www.fff.fr/la-vie-des-clubs/***/page-classement/competition-283517/phase-1/groupe-1</classement>
          </ResultatsItem>
    Jul 02, 2013 @ 16:05
    Jeroen Breuer
    Something like this should probably work now:
        var image = item.Image;
        <li>
            <img src="@image.umbracoFile" alt="@image.nodeName"/>
        </li>
    Jeroen
    Jul 02, 2013 @ 16:16
    Joe
    Not work ! That does not work as a media Picker?
    Jul 02, 2013 @ 16:21
    Jeroen Breuer
    Is your Model the current page and does that current page have the photosDuMatch property? What version of Umbraco are you using?
    Jeroen
    Jul 02, 2013 @ 16:28
    Joe
    Umbraco v6.0.2
    I have just seen that when I select an image and what I back up, I return then on my page the image is not there any more.
    Jul 02, 2013 @ 16:33
    Jul 02, 2013 @ 16:42
    Joe
    There is another means to load several embellish with images without having to ask them one by one with a media to picker?
    Jul 02, 2013 @ 16:47
    Jeroen Breuer
    You could select a media folder and display the content of the folder. I do the same thing on this page which is also in the DAMP Gallery.
    Jeroen
