Topic author was deleted
Jeroen,
On a fresh install (and all of our ther v6.1.3's), when you click 'edit' for an item, the file will upload properly; but the meta data stays the same.
Replicate the issue by:
- Install fresh Umbraco 6.1.3
- Install DAMP 2.5
- Add DAMP to a document
- Add an image via DAMP
- Now click edit, choose a different file.
- File meta stays the same despite the file actually being uploaded to the /media folder
kevin
Hi Kevin,
This bug already exists since Umbraco v6. I still need to release DAMP 2.6 with the fix in it. For now you can find the fix on CodePlex: https://damp.codeplex.com/SourceControl/changeset/c596a606fa35
Jeroen
Comment author was deleted
Thanks!
I've released DAMP 2.6 in which this bug and some other bugs are fixed.
"Edit" feature doesn't work with v6.1.3
Jeroen,
- Install DAMP 2.5
kevin
Hi Kevin,
Jeroen
Thanks!
Jeroen
