  • Ali Sheikh Taheri 470 posts 1648 karma points c-trib
    Sep 10, 2013 @ 18:44
    Ali Sheikh Taheri
    save doesn't work with custom property
    I ma using umbraco 6.1.5 and with latest DAMP.
    I've got a TextString Property for AltText and when I fill it in with Damp it doesn't save that property in media.
    Any Help?
    Cheers Ali
    Sep 11, 2013 @ 09:15
    Jeroen Breuer
    It's a know issue and I'll try to release DAMP 2.6 with the fix soon. For a workaround look in this topic: http://our.umbraco.org/projects/backoffice-extensions/digibiz-advanced-media-picker/digibiz-advanced-media-picker/44199-Edit-feature-doesnt-work-with-v613
    Jeroen
    Sep 11, 2013 @ 10:55
    Ali Sheikh Taheri
    Hi shall I just dumb that file in bin folder / download the source code, compile the code and move the dll into bin?
    Sep 11, 2013 @ 10:56
    Jeroen Breuer
    Yes just copy over the bin files from the source code to the Umbraco site bin folder.
    Jeroen
    Sep 11, 2013 @ 11:03
    Ali Sheikh Taheri
    Thanks Jeroen, it works like a charm! Cheers Ali
    Sep 16, 2013 @ 12:14
    Jeroen Breuer
    I've released DAMP 2.6 in which this bug and some other bugs are fixed.
    Jeroen
    Sep 16, 2013 @ 12:20
    Ali Sheikh Taheri
    thanks Jeroen, I will update it Cheers Ali
