  • Dennis Pedersen 8 posts 71 karma points c-trib
    Oct 27, 2011 @ 12:01
    Dennis Pedersen
    Access to "Settings" is required
    Thank you for this great addition. Though I cannot get it to work as I expect.
    I do the following:
    1. Create a new user, set user type as Administrator (reproducible as Writer, Editor etc. too).
    2. Assign "[language]" section as the only section for the user. Save.
    3. Login as the new user. Click on an existing translation.
    HAPPENS: Server error, "The current user doesn't have access to the section/app 'settings'".
    If I go back to the admin user and enable the "Settings" section, then it works as expected but the new user also sees the "Settings" icon in the dashboard and is able to create/edit/delete in there, which was the point they shouldn't be able to.
    Have I overlooked some setting on the user?
  • Jeroen Breuer 4908 posts 12265 karma points MVP 4x admin c-trib
    Oct 27, 2011 @ 12:04
    Jeroen Breuer
    Hi Dennis,
    This is a bug in my package which is new since Umbraco 4.7.1. Have a look at this blog to solve it: http://www.richardsoeteman.net/2011/10/17/FixUserPermissionsErrorInDigibizDictionarySection.aspx.
    Jeroen
    Oct 27, 2011 @ 15:30
    Dennis Pedersen
    That did the trick, thank you for a prompt and accurate reply :-)
  • Stefan Kip 1614 posts 4131 karma points c-trib
    Nov 15, 2011 @ 09:46
    Stefan Kip
    Thanks Jeroen, had the same problem! :-)
