  • Warren Buckley 2106 posts 4836 karma points MVP 8x admin c-trib
    Jan 28, 2014 @ 11:20
    Warren Buckley
    Suggestion - Right Sidebar dialog
    This looks great, I haven't had a chance to install it yet.
    But from the screenshots you have a popup window to select the files.
    Can I make a suggestion that the file picker is put into a dialog slideout on the right hand side so it fits more into the UI of Umbraco.
    Here is a code snippet that I am using on my Umbraco NuGet POC
    //Click Button - Pick Files
            $scope.pickFiles = function (folder) {
                //Open a dialog - passing in a ton of options
                dialogService.open({ template: '../App_Plugins/NuGet/BackOffice/Packages/partials/dialogs/file-picker.html', callback: filesPicked, dialogData: { Folder: folder } });
                //When the node has been picked - do this...
                function filesPicked(pickedFiles) {
                    //Log the JSON object we get back from the dialog picker
                    console.log(pickedFiles);
  • lucuma 261 posts 563 karma points
    Jan 28, 2014 @ 12:47
    lucuma
    I originally started this package as a means to learn/use the dialogService (thanks for the code by the way) however for the sake of ease I used the dropbox dropin plugin which does not require any serverside code, the application to be approved (by dropbox) nor to use oath. It also means I have to live with how it pops open/etc.
    I may extend this component to have a server side piece that would allow me to do this, but right now I'm just working on packages that are front end only.
    Thanks for your feedback!
