  • Eran 292 posts 436 karma points
    Sep 16, 2010 @ 16:15
    Eran
    problem after install/uninstall
    hey matt,
    i have win 7 with IE9 beta.
    after installing your package, i could'nt enter the umbraco admin page from IE9:
    "object not set to an instance of an object".
    so, i go to Firefox and entr the admin to uninstall the package. from FF i could enter and uninstall it.
    after that, the site totally crash (the backend and the front):
    "could not load assembly "TheOutField.UmbExt.IE9Extensions. the system cannot find the file specified".
    i manage to fix it after manually remove the following line from the web.config:
    <add name="IE9ExtensionsModule" type="TheOutfield.UmbExt.IE9Extensions.IE9ExtensionsModule, TheOutfield.UmbExt.IE9Extensions" />
    FYI,
    Eran.
  • Matt Brailsford 4125 posts 22224 karma points MVP 9x c-trib
    Sep 16, 2010 @ 16:18
    Matt Brailsford
    Hi Eran,
    What version of Umbraco are you using? And what version of IIS?
    Many thanks
    Matt
    Sep 16, 2010 @ 16:26
    Eran
    i'm using IIS7 and Umbraco v4.5.1
    BTW, its not local server, its softsys shared hosting.
    Eran.
    Sep 16, 2010 @ 16:28
    Matt Brailsford
    Hi Eran,
    .NET 4 or .NET 3.5?
    Many thanks
    Matt
    Sep 16, 2010 @ 16:34
    Eran
    .NET 4.
    Sep 16, 2010 @ 16:48
    Matt Brailsford
    Hmmm,
    I'm not entirely sure then as it doesn't really do that much. Could do with a stack trace or something around the "Object reference..." bit to be able to narrow it down really.
    The uninstall I can take a look at (not sure whether it's due to an issue I've noticed recently http://umbraco.codeplex.com/workitem/28829) as it should uninstall itself.
    On another note though (and I'm sure you know, but I need to be clear), this package is very much in Alpha and was pretty much put together for the challenge of it seing as is was released on the same day as the IE9 Beta release. The Umbraco 4.6 update coming soon will have all of these features included as standard, so this package will no doubt be defunked. By all means install it to see what is possible, but I wouldn't advise you install it on a live environment.
    Many thanks
    Matt
    Sep 16, 2010 @ 17:01
    Eran
    i understand and just the fact that you publish a package for IE9 on the same day that IE9 released its great!
    i'm sure that it will be solved.
    Eran.
    Sep 17, 2010 @ 19:40
    Matt Brailsford
    Hey Eran,
    That should be fixed now, I managed to find a way to replicate it.
    Cheers
    Matt
  • Aron Gamble 63 posts 76 karma points
    Sep 20, 2010 @ 10:07
    Aron Gamble
    I've had the same problem - i copied over the updated dll but the problem is still there. Is there anything else i should do?
    Aron
    Sep 20, 2010 @ 10:14
    Matt Brailsford
    @Ardon You get "object not set to an instance of an object"?
    Do you have a stack trace?
    Many thanks
    Matt
    Sep 20, 2010 @ 12:05
    Aron Gamble
       TheOutfield.UmbExt.IE9Extensions.Filters.IE9ExtensionsFilter.Write(Byte[] buffer, Int32 offset, Int32 count) +819
       ClientDependency.Core.Module.ResponseFilterStream.Write(Byte[] buffer, Int32 offset, Int32 count) +170
       System.Web.HttpWriter.FilterIntegrated(Boolean finalFiltering, IIS7WorkerRequest wr) +358
       System.Web.HttpResponse.FilterOutput() +120
       System.Web.CallFilterExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +173
       System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +265
    Sep 20, 2010 @ 12:11
    Matt Brailsford
    Hmmm, that is weird, sounds like the same problem, but it's definatley fixed in the latest version.
    I'll have another look though incase I've missed something.
    Cheers
    Matt
