  • Sotiris Filippidis 286 posts 1501 karma points
    Dec 28, 2017 @ 21:44
    Sotiris Filippidis
    Boostrap style labels
    This is not a question, I just wanted to share a little snippet that might make your labels more attractive. I just applied Bootstrap classes to the message (the Umbraco back-end supports Bootstrap) and now it is presented as an Info Alert with a close button.
    <div class="alert alert-info alert-dismissable">
        <a href="#" class="close" data-dismiss="alert" aria-label="close">&times;</a>Your text here</div>
    Great little data type this one!
  • Jason Prothero 422 posts 1243 karma points MVP 2x c-trib
    Jan 02, 2018 @ 16:44
    Jason Prothero
    Thanks! I'll take a look and see if I can get a new release out in the near future.
    -Jason
