Weird, I was just about to post with the same issue.
The solution I have so far is to use the Visual Studio Custom Tool and then manually cast the object.
It's a pain in the arse though. I assume it is something to do with the detached models or something like that that I've seen discussed before.
[IgnorePropertyType("usefulLinks")]
[IgnorePropertyType("navigation")]
public partial class Footer
public IEnumerable<NavigationItem> UsefulLinks
get
var usefulLinks = this.GetPropertyValue<IEnumerable<IPublishedContent>>("usefulLinks");
return usefulLinks.Select(x => new NavigationItem(x));
public IEnumerable<NavigationListWithTitle> Navigation
get
var navigation = this.GetPropertyValue<IEnumerable<IPublishedContent>>("navigation");
return navigation.Select(x => new NavigationListWithTitle(x));
A cool thing is that the IPublishedContent you get from Nested Content can also be converted to a strongly typed model because it's based on a document type which also has a model. More info about that in this blog: http://24days.in/umbraco/2015/multilingual-vorto-nested-content/
Lee: Thanks for releasing 0.3.0 with the better ModelsBuilder support in it.
The IPublishedContent objects that it returns are still not the ModelsBuilder IPublishedContent wrapper objects though. Is there any way to achieve this so that you can just do:
rather than having to create a partial class of MyModel to override the MyNestedContentProperty property and call the constructor of MyOtherModel for each IPublishedContent in MyNestedContentProperty? e.g.
return this.MyNestedContentProperty.Select( c => new MyOtherModel(x));
Which meant that ModelsBuilder would use that type for the property.
I'm not sure how OfType() extension would work in that context?
If you think there is something missing that we need to add to Nested Content to support this scenario? We're all ears. Otherwise I don't know what to suggest.
No worries Lee. The attribute addition is very welcome. It's not a big deal to work around it, I'm just being anal.
It seems that the content factory that the Models Builder comes with, isn't used for your detached content gubbins. I guess with it going in to the core it may be useful to resolve at some point. If only there was a package where you could create a model with an extension method .
You can manually create ProeprtyConverters for your custom types that map directly to strong typed models. There is an example(though its for a different plugin).
namespace Proteus.DataTypeModels
public class Carousel : JObject
public Carousel(JObject data)
:base(data)
public new static IEnumerable<Carousel> Parse(string json)
return JArray.Parse(json).Children().Select(s => new Carousel((JObject)s));
/// <summary>
/// Full Image: Banner Image to use on desktop devices.
/// </summary>
public IPublishedContent FullSrc
get
return this["FullSrc"] == null || String.IsNullOrEmpty(this["FullSrc"].Value<string>()) ? null : UmbracoContext.Current.MediaCache.GetById(this["FullSrc"].Value<int>());
/// <summary>
/// Small Image: Smaller image to use on tablet or mobile devices.
/// </summary>
public IPublishedContent SmallSrc
get
return this["SmallSrc"] == null || String.IsNullOrEmpty(this["SmallSrc"].Value<string>()) ? null : UmbracoContext.Current.MediaCache.GetById(this["SmallSrc"].Value<int>());
/// <summary>
/// Alt Text: Alt text to add to the images. If not specified the image name will be used instead.
/// </summary>
public string AltText
get
return this["AltText"] == null ? String.Empty : this["AltText"].Value<string>();
/// <summary>
/// Link To Document: A document to link to when the banner is clicked.
/// </summary>
public IPublishedContent LinkToPage
get
return this["LinkToPage"] == null || String.IsNullOrEmpty(this["LinkToPage"].Value<string>()) ? null : UmbracoContext.Current.ContentCache.GetById(this["LinkToPage"].Value<int>());
/// <summary>
/// Link Query String: An optional query string to append to banner link. Should start with a ? if used.
/// </summary>
public string LinkUrl
get
return this["LinkUrl"] == null ? String.Empty : this["LinkUrl"].Value<string>();
/// <summary>
/// Hidden: If this item visible by default. Items can be hidden and displayed through Test & Target.
/// </summary>
public bool Hidden
get
return this["Hidden"] != null && this["Hidden"].Value<string>() == "1";
/// <summary>
/// Unique Name: Unique name for this item to use in analytics and scripting.
/// </summary>
public string UniqueName
get
return this["UniqueName"] == null ? String.Empty : this["UniqueName"].Value<string>();
Building a property converter that modifies how Model Builder binds the property is certainly the best way to accomplish what you want to do.
But for folks who don't want to go down that road I thought I'd share another option. Let the generated model properties remain IPublishedContent and IEnumerable<IPublishedContent> and instead use an HTML helper extension to map the IPublishedContent item to the generated model and then to a partial view.
Model Builder with Nested Content
Hey Lee,
I'm trying out the new V7.4.1 with the ModelsBuilder but it picks up Nested Content as object instead of IEnumerable
Can you point me to the right direction on how I should create a converter to it will return the right type?
Btw i'm using Nested Content 0.2.0 from Nuget
Hi JLon,
Unfortunately I haven't had opportunity to try out ModelsBuilder with Nested Content yet. I don't know enough about it to offer any useful advice.
Hopefully someone who has experience with ModelsBuilder will jump in on this thread.
- Lee
This example uses an old version of the models builder, but it should still work the same. You need to create a partial class and implement the property there yourself: https://gist.github.com/jbreuer/0a5996e5e6bf881ce847#file-gistfile1-cs-L28
Jeroen
Ahhh, it's suddenly come back to me... we have an (unreleased) fix for this.
See these GitHub issue + pull-request:
https://github.com/leekelleher/umbraco-nested-content/issues/49
https://github.com/leekelleher/umbraco-nested-content/pull/51
If you wanted to use the latest (bleeding-edge) development version of Nested Content, you can grab the package file from here:
https://ci.appveyor.com/project/leekelleher/umbraco-nested-content/build/0.2.0.69/artifacts
It should be pretty stable, but usual risks/warnings apply.
- Lee
aha lee, that seems to have worked. will the fix be release anytime soon as one of the latest package?
Jeroen, i'll try out the partial class as well too.
You guys are legend :)
Hi David,
Honestly, I have no idea. I still haven't got around to using ModelsBuilder yet, so I'm not in a position to make suggestions on its usage.
For NestedContent, we literally added this line: ref
I'm not sure how
OfType()
extension would work in that context?If you think there is something missing that we need to add to Nested Content to support this scenario? We're all ears. Otherwise I don't know what to suggest.
- Lee
That would be cool ;-)
Yup, Ditto! :-P
Property Converter:
Model:
IPublishedContent
andIEnumerable<IPublishedContent>
and instead use an HTML helper extension to map theIPublishedContent
item to the generated model and then to a partial view.You can see the details in this gist: https://gist.github.com/ChesterCampbellAM/2e9e14de81a4ee242eee46ce6c4936e4
