  • Jay 425 posts 652 karma points
    Sep 28, 2016 @ 12:00
    Jay
    Does it works with Courier
    Hey Dave,
    Quick question, do the OEmbed Picker Property Editor works with Courier? Wanted to use it but the client is using Courier on the site so checking to see if this works with Courier
    Sep 28, 2016 @ 12:08
    Dave Woestenborghs
    Hi JLon,
    This package has been marked to work on Umbraco as a Service. This uses courier to deploy content changes.
    So I'm 99.99% sure it works with Courier.
    Dave
    Sep 28, 2016 @ 12:51
    Jay
    Sweet. Thanks Dave
    Sep 28, 2016 @ 13:58
    Jay
    Hey Dave,
    Quick question, will it be possible/easy to hide the size bits from the user?
    I don't want the user to be able to set the width and height
    Sep 28, 2016 @ 16:03
    Dave Woestenborghs
    Hi JLon,
    Not out of the box, because this uses the same dialog that you get when you use the embed option in the rich text editor or the embed grid editor. The only option as I now can see is that you create your own OEmbed provider that hard codes these values.
    Tim Geyssens created a blog post describing how to create a custom provider : http://www.nibble.be/?p=451
    This is the source code of the current one used for youtube and other video providers : https://github.com/umbraco/Umbraco-CMS/blob/dev-v7/src/Umbraco.Web/Media/EmbedProviders/OEmbedVideo.cs
    You will need to override the SupportsDimensions property and set it to false. Like in this provider https://github.com/umbraco/Umbraco-CMS/blob/dev-v7/src/Umbraco.Web/Media/EmbedProviders/Twitgoo.cs
    And maybe hardcode your dimensions. After that you need to update the EmbeddedMedia.config to use your provider for video.
    Dave
    Sep 28, 2016 @ 17:01
    Jay
    Thanks Dave
    Sep 30, 2016 @ 15:19
    Dave Woestenborghs
    Hi JLon,
    Just curious. Did you solve your issue ?
    Dave
