  • blackhawk 313 posts 1368 karma points
    Nov 28, 2017 @ 20:53
    blackhawk
    Using statement for this package
    Is there a using statement we should be referencing in our views when using this package? When I place the following code into my view...
    @inherits Umbraco.Web.Mvc.UmbracoTemplatePage<ContentModels.ContentPage>
    @using ContentModels = Umbraco.Web.PublishedContentModels;
    @using Umbraco.Web;
    @using Umbraco.Web.Models;
            var membed = Model.Content.GetPropertyValue<List<MvcHtmlString>>("videoEmbed");
            <div>
                @membed;
    My web page outputs the following as a string...
      System.Collections.Generic.List`1[System.Web.Mvc.MvcHtmlString];
    I'm on Umbraco 7.6.7
  • Dave Woestenborghs 3494 posts 12077 karma points MVP 7x admin c-trib
    Dec 02, 2017 @ 11:04
    Dave Woestenborghs
    Hi Blackhawk,
    I need to update this package it think for better support with models builder.
    Will see if I can put out a new release this week.
    Dave
    Dec 02, 2017 @ 13:07
    blackhawk
    Awesome! And thanks for looking into it.
    Dec 02, 2017 @ 13:15
    Dave Woestenborghs
    I just released version 3.0.0
    This should fix your problem. Seeing that you are using Modelsbuilder you can use this syntax assuming you are allowing multiple video's to be selected
    @using Umbraco.Web;
        @foreach(IHtmlString embed in Model.Content.VideoEmbed)
    @embed
    Dave
    Dec 02, 2017 @ 15:01
    Dave Woestenborghs
    2
    Hi Blackhawk,
    I just released v3.0.0 which has better models builder support.
    You can now do this
    @foreach(var embed in Model.Content.VideoEmbed)
    <div>@embed</div>
