  • Mike Chadwick 41 posts 182 karma points
    Dec 14, 2016 @ 05:54
    Mike Chadwick
    Rank One and Vorto
    Hi Mark,
    Great work on Rank One SEO. Is this compatible with Vorto? We have set up a site with Vorto but the SEO doesn't seem to be working.
    This would be great if it had a Vorto enable mode and used Umbraco language and culture settings automatically.
    If it can be used with Vorto, any tips on how it needs to be configured for optimum performance?
    Mike
  • Mark Wemekamp 73 posts 385 karma points
    Dec 19, 2016 @ 16:31
    Mark Wemekamp
    Thanks Michael :)
    I'll look into it, I haven't used it myself with Vorto. I'm going to build a testcase for it and figure out how we can combine both
    Keep you posted
  • Rafael Gimeno 16 posts 99 karma points c-trib
    Jan 05, 2017 @ 14:21
    Rafael Gimeno
    Any news on this? It would be very interesting to integrate Vorto with Rank One ;)
    Jan 10, 2017 @ 11:41
    Mark Wemekamp
    Hi Michael and Rafa,
    Sorry for the late response
    I've built te most simple testcase I could think of and this seemed to be working.
    1. I created a doctype with a Vorto wrapped Textstring and added a dashboard property Vorto wrapped textstring
    2. Filled the property in the content section
    3. Created a template that outputs the value
      @inherits Umbraco.Web.Mvc.UmbracoTemplatePage<IPublishedContent>
      @using Our.Umbraco.Vorto.Extensions
          Layout = null;
          var testProperty = Model.Content.GetVortoValue<string>("testProperty");
      @testProperty
    This outputs online my value I filled in at step 2
    The RankOne dashboard gives the following output RankOne output
    Could you elaborate on the problem you're experiencing?
    Are you receiving an error?
    How should I change my test scenario to match your environment?
    Kind regards,
    Mark
  • Simon 692 posts 1068 karma points
    Jan 16, 2017 @ 09:06
    Simon
    Hi Mark,
    I am having problems when my seo meta tags properties are vorto properties. It is working, but the dashboard is saying that there are error regarding meta description etc.. and event the preview is not working fine.
    Jan 16, 2017 @ 09:10
    Mark Wemekamp
    Ah, so you've wrapped the dashboard and preview in a Vorto property? I haven't tried that out myself but will look into that.
    I will keep you posted
    Jan 16, 2017 @ 09:12
    Simon
    No not exactly. Just wrapped the SEO Meta Title and Meta Description in Vorto Properties, but the preview is not working properly and the dashboard is saying that I have a meta description error.
    Jan 16, 2017 @ 09:13
    Mark Wemekamp
    Ok, I'll try to reproduce it
  • René 327 posts 852 karma points
    Jun 15, 2017 @ 18:42
    René
    Huge thanks for all the effort you have put in to Rankone :-)
    Is there any news on vorto and preview
    René
