I am attempting to install Mark Wemekamp RankOne - SEO Toolkit (https://our.umbraco.org/projects/backoffice-extensions/rankone-seo-toolkit/) and either i'm missing something obvious or its simply just not working for me.
I am attempting to install this locally via visual studio nuget package console using Install-Package RankOne. My umbraco version is Umbraco version 7.4.2 assembly: 1.0.5921.28477
The following is being installed into my solution
When looking into document types in settings there is no RankOne - Seo Compositions document type neither is it available when i attempt to add it as a composition to an existing or new document type.
Hi Paul,
Unfortunately installing it through nuget will not create the documenttype. This functionality only works in the Umbraco package and I haven't figured out yet if it is possible through nuget.
I'll look into the dashboard problems, haven't seen that before.
RankOne - SEO Toolkit install help
Also, as outlined https://github.com/markwemekamp/RankOne-Umbraco-SEO-Tool i have added the following to dashboard.config and although i am receiving a score when i select error's and hints there is no info available
I have rebuilt the solution, cleaned and also re-started everything in IIS but no luck.
Any ideas?
Thanks Paul
Hi Paul, Unfortunately installing it through nuget will not create the documenttype. This functionality only works in the Umbraco package and I haven't figured out yet if it is possible through nuget.
Kind regards,
Mark
Hi Mark,
Thanks for taking the time to get back. Ahh that's cool, i have just added my own document type and added the property editors to it.
I must say I am very impressed with the package and what it has to offer. Thanks for your hard work and sharing with the community :)
Many thanks Paul
