  • Rylan 69 posts 253 karma points
    Jul 25, 2017 @ 22:39
    Rylan
    "Title is longer than 60 characters..." 7.6 Error
    On every page using the dashboard, it says that my page title is too long, even when the title is only 10 characters long.
    This must be a glitch in the system not counting properly.
  • Mark Wemekamp 73 posts 385 karma points
    Jul 26, 2017 @ 10:30
    Mark Wemekamp
    Could you post the head html of your page?
    The analyzer is tested thoroughly so i suspect this could be faulty html
    Jul 26, 2017 @ 17:12
    Rylan
    I was using:
    <title>@Umbraco.Field("seoTitle", altFieldAlias: "pageName") | @homePage.siteName</title>
    Then I switched it to this to see if it would fix it and it did not:
    <title>@CurrentPage.seoTitle | @homePage.siteName</title>
  • Bruno Olsen 75 posts 316 karma points
    Aug 02, 2017 @ 13:16
    Bruno Olsen
    It says that even if the title tag is as simple as
     <title>Lorem</title>
    on 7.6.1 ;)
    Kind regards, Bruno
    Aug 02, 2017 @ 13:18
    Mark Wemekamp
    I'll try to look into it as soon as possible
    Aug 04, 2017 @ 11:10
    Mark Wemekamp
    Fixed this problem in the code
    https://github.com/markwemekamp/RankOne-Umbraco-SEO-Tool/commit/03457ae43b0bcbca940acde9e428a6eac1ce6c1e
    I´m planning on releasing a new version later in the day
    Thanks for reporting
