  • Oleg 13 posts 33 karma points
    Nov 19, 2014 @ 14:23
    Oleg
    Umbraco 7.1.x compatibility
    The package work well, but in the back office I can't see the values.
  • Zac 239 posts 541 karma points
    Nov 19, 2014 @ 16:25
    Zac
    Can you clarify?  Where can't you see the values?  What SQL did you use for your data type?
    This package is supposed to allow you to select values from the database.  It doesn't let you add, remove, or modify the database values if that's what you are expecting.
    Nov 19, 2014 @ 16:56
    Oleg
    Thank you for response,
    I'm using Sql Server 2012.
    Umbraco version: 7.1.8
    In Production I can see the values
    But in backoffice I can't
    Here the DataType I'm using
    Best regards,
    Oleg.
    Nov 19, 2014 @ 17:00
    Zac
    The query and setup look fine.
    Is this table in the same database as Umbraco?  The Sql Dropdown List uses Umbraco's connection string.
    Does that query execute fine in your database?
    Nov 19, 2014 @ 21:24
    Oleg
    Yes, countries table in the same database as Umbraco.
    I success to save and extract the parameter from/to the member property country (data-type: countries as I show you above), but I can't manage it from backoffice.
    There example of members http://www.groopy.com/members. You can see that every member has country.
