  • Peter Cort Larsen 421 posts 1038 karma points
    Jan 19, 2015 @ 22:53
    Peter Cort Larsen
    No values in backend
    i dont get any values, when i use this as a property on a node.
    The table is in the same database as the solution.
    I relly need this, it would be great if it culd work.
    I use 7.2.1
  • Zac 239 posts 541 karma points
    Jan 20, 2015 @ 19:58
    Zac
    Hi Peter,
    I'm not sure what's going on.  If you execute your sql statement directly in the database do you get a result?  It's a pretty simple package and should work fine but I haven't tested on 7.2.1.  Also, I'm not planning on maintaining this package anymore, since nuPickers offers this functionality as part of it's package.  I'd check that out: http://our.umbraco.org/projects/backoffice-extensions/nupickers
    Jan 20, 2015 @ 20:17
    Peter Cort Larsen
    Yes the SQL works. Ok ill check out NU pickers.
    Thanks.
