I think it was Tab Icons that caused this issue, as after I removed it, the issue went away. The issue is, when ever I make any updates in edit mode, the right hand side area shrinks, leaving a horizontal scroll bar. See below for a screen shot.
I also have the following other packages installed
I reinsatlled, recycled the app pool, but still got the same issue. I was using Firefox 5, so I've updated to the latest version, but that didn't make any difference.
Sorry for the delay in response... I have not come across this issue.
Leave Tab Icons installed and remove each of the other packages to see it goes away. The reason is to find which package is conflicting with Tab Icons to cause this.
Issue with 4.7.1
http://our.umbraco.org/forum/getting-started/installing-umbraco/27506-Strange-behaviour-in-edit-mode?p=0#comment102892
Hi Danny
So the issue persists after you uninstalled the tab icons package? And what browser are you using?
Have you tried to recycle the app pool after you uninstalled the package?
The issue goes away once I uninstall the tab icons package.
I am using Google Chrome, but issue is also present in Firefox
Will try reinstalling and doing the app pool recycle
OK. I've just done that then.
Cheers
Danny
Thanks and again.. sorry for the delay.
