  • Peter Norbeck 7 posts 27 karma points
    Feb 24, 2012 @ 21:38
    Peter Norbeck
    Dashes are removed from cells on output
    All dashes that are written in the cells are removed on output. For example if I write -19 in a cell and saves the content the value saves correctly but when i try to output the tabular data with razor the -19 outputs 19. The dash is gone.
    This is how I output the Tabular Data content with Razor.  I named the field in umbraco to table:
    <umbraco:macro runat="server" language="cshtml">
    <table>
    @* HEADER *@
    @if( @Model.table.BaseElement.Element("Body") != null ){
    foreach(var row in Model.table.Body.Row ){
    <tr>
    @foreach(var cell in row ){
    <td>@cell.InnerText</td>
    </tr>
    </table>
    </umbraco:macro>
    Info:
    Umbraco version: 4.7.1
    IIS version: 7.5
    .net version: 4.0.30319.1
  • Mike Taylor 155 posts 353 karma points
    Feb 24, 2012 @ 22:23
    Mike Taylor
    Thanks for reporting this - I'll take a look into it.
    Mike
    Mar 03, 2012 @ 01:32
    Mike Taylor
    Looks like this is a known issue - see http://umbraco.codeplex.com/workitem/30680 - will investigate further.
    Mar 03, 2012 @ 13:47
    Mike Taylor
    OK - I can confirm that this is a bug in 4.7.1.1, and I've managed to get it working by grabbing umbraco.MacroEngines.dll from the latest nightly at http://nightly.umbraco.org/umbraco%204.7.1/4.7.1/
    Let me know if that works for you.
    Mike
