  • David W. 159 posts 284 karma points c-trib
    Jun 01, 2012 @ 14:51
    David W.
    Razor/XSLT-samples
    Looking forward to try this, but it would be nice to have some sample code on how to fetch and render the data.
    Thanks.
  • Mike Taylor 155 posts 353 karma points
    Jun 01, 2012 @ 14:57
    Mike Taylor
    Here's a quick Razor example --- obviously, you may want to do things differently depending on how you want to output the data. (Ignore lines 13-18, they're rendering other fields from my doctype).
    http://snipt.org/ujijc1
  • DanH 36 posts 61 karma points
    Mar 13, 2013 @ 22:34
    DanH
    Here's a really simple version that can be customized:
    @using Umbraco.Core.Dynamics
    DynamicXml rates = (DynamicXml)Model.Content["table"];
    <table>
    <tbody>
    @foreach (var row in rates.BaseElement.Descendants("Row"))
    <tr>
    @foreach (var col in row.Descendants())
    <td>
    @col.Value
    </td>
    </tr>
    </tbody>
    </table>
