However default is set to five rows, so when the node is published I get five empty rows in the html. I could just delete the rows or set default rows just to one.. but is there a way I easily can check if the cells in a row have values (cell not is empty or only contains blank spaces) before I build the html tablerow?
Only create rows which have values
Hi...
I have looked at the razor example from here to use Tabular Data: http://snipt.org/ujijc1
I have ended up with this code:
@if(Model.HasValue("productSpecs")) { <div class="tab-pane fade active in" id="tab-1"> @{ DynamicXml specs = (DynamicXml)Model.productSpecs; ArrayList colWidth = new ArrayList(); var hasRowHeader = (specs.BaseElement.Elements("Body").First().Elements("Row").First().Elements("RowHead").Count() > 0); } <table border="0" class="table table-striped"> @foreach (var item in specs) { string closeTag = "</tbody>"; switch ((string)item.BaseElement.Name.ToString()) { case "Columns": foreach (var column in item.BaseElement.Elements("Column")) { colWidth.Add(column.Attribute("width").Value); } break; case "Header": @:<thead> closeTag = "</thead>"; break; case "Footer": @:<tfoot> closeTag = "</tfoot>"; break; case "Body": @:<tbody> break; } if (item.BaseElement.Name != "Columns") { foreach (var itemRow in item.BaseElement.Elements()) { @:<tr> var isFirst = true; foreach (var itemDataCell in itemRow.Elements()) { string cellTag = (itemDataCell.Name == "RowHead" || itemDataCell.Name == "ColHead") ? "th" : "td"; string cellClass = itemDataCell.Name.ToString() + " " + item.BaseElement.Name.ToString(); if (item.BaseElement.Name == "Header" && hasRowHeader && isFirst) { cellClass += " tblTitle"; } @Html.Raw("<" + cellTag + " class=\"" + cellClass + "\">"); @Html.Raw(itemDataCell.Value); @Html.Raw("</" + cellTag + ">"); isFirst=false; } @:</tr> } @Html.Raw(closeTag) } } </table> </div> }However default is set to five rows, so when the node is published I get five empty rows in the html.
/Bjarne
