  • Martin Lingstuyl 202 posts 379 karma points
    Jul 23, 2013 @ 10:11
    Martin Lingstuyl
    Hide errors to clean up logs
    Thanks for the plugin, great work. Could you send me the sourcecode for the usercontrol though? I'd like to add a feature to be able to hide errors so the errorlog can be cleaned up. Handy if you're in debug fase and getting a lot of errors. Thanks in advance!
    Martin
  • Murray Roke 503 posts 967 karma points c-trib
    Jul 24, 2013 @ 03:34
    Murray Roke
    Hi Martin
    I've pushed up the bare minimum into GitHub, I think this is all that you need, but the project I had it in before had a bunch of unrelated stuff I wanted cleaned out, also not sure the best way to set up a working umbraco version in github to test against, sounds like something to read up on when I have some time  :-]
    https://github.com/Myster/TerabyteElmah
    Jul 24, 2013 @ 08:34
    Martin Lingstuyl
    Thanks a lot, will look into it.
    Time is always short, isn't it? :)
    Do you want me to post the new control back to you? (I'll add some log management features.)
    Jul 26, 2013 @ 03:33
    Murray Roke
    yea, do a pull req if you like and ill try figure out what to do with it :-)
