  • Doron 6 posts 28 karma points
    Mar 27, 2014 @ 08:52
    Doron
    Drop down editor problem
    Nice package, we were missing data-grid in v7.
    There is a small bug in the dropdown editor.
    propertiesViews\dropdown.html has
      <option ng-repeat="option in model.config.columns.columns[$index].props.options" value="option.value">{{option.text}}</option>
    When it should be
      <option ng-repeat="option in model.config.columns.columns[$index].props.options" value="{{option.value}}">{{option.text}}</option>
    otherwise you always get 'option.value' as your data.
    You might also want to take a look at the ngOptions directive  it makes life much simpler.
  • gilad 185 posts 425 karma points
    Mar 27, 2014 @ 09:13
    gilad
    Hi Doron.
    Thanks for that,
    I changed it to ng-options.
    I'll update the project later today.
    Cheers.
