Hopefully the creator of the package will see these posts soon :)
EDIT: It's a bit of a shame that the project is not on GitHub so the community could perhaps try and fix the issue by creating a pull request to target the issue. Hope that Gilad will consider this at some point.
We are using U7DTG v1.1.1 with Umbraco v7.1.3, and it works fine (RTE with one instance of U7DTG, two instances of U7DTG, ...). Which version of umbraco are you using?
The package comes with the full source code (no .dll or compiled code) ... but needs some knowledge about Angular.Js
A possible workaround could be to have the RTE on a TAB and the U7DTG on another tab.
V1.1.1 Richtext Editor not working
First i like to say well done on creating this editor! :)
Now to the problem, i have a richtext editor as a property both in the grid and as page property, the grid rte interfears with the page
rte look on the below images.
I have done some more testing and it seams to only fail when you add a new row if one saves the page and
reloads then it all works until one hits add row.
Before adding a grid row:
After adding a grid row:
Hi Robert
Seems like you're not the only one having this issue - http://our.umbraco.org/projects/backoffice-extensions/u7-grid-data-type/questions-bugs-issues-feedback/49527-Rich-Text-Editor-Not-Displaying
Aha, i dide read on that post but was unsure if it was related to this issue, hopefully this gets fixed as its really a nice editor :)
