Hi, I'm having trouble with pulling the individual values from the data grid. I can get the full string with both label and value, but i'm new to razor and having trouble.
@widget.featureBlock gives me everything within the datatype.
[ { "blockTitle": "Feature Block 1", "blockParagraph": "Feature Block 1 Content", "blockIcon": "1094", "urlPicker": "1062" }, { "blockTitle": "Feature Block 2", "blockParagraph": "feature Block 2 Content", "blockIcon": "1095", "urlPicker": "1054" } ]
My razor macro is
@{ var widgetsFolder = Model.WidgetsFolders.Where("Visible").First(); } @foreach (dynamic widget in widgetsFolder.Children.Where("Visible and nodeTypeAlias.StartsWith(\"Widget_\")")) { string widgetType = widget.NodeTypeAlias.ToString(); switch (widgetType) { case "Widget_FeatureBlocksReveal": @showFeatureBlocksReveal(widget); break; default: <b>Unknown Widget!</b> break; } } @helper showFeatureBlocksReveal(dynamic widget){ if (!string.IsNullOrEmpty(widget.featureBlock.ToString())) { foreach(dynamic content in widget.featureBlock) { @content.blockTitle } } }
Any help would be grateful.
Martin
Hi Martin.
Which version of umbraco do you use?
Your helper looks fine..
Try to use the example from the project page:
@helper showFeatureBlocksReveal(dynamic widget){ if(!string.IsNullOrEmpty(widget.featureBlock.ToString())) { foreach(var content in widget.featureBlock) { <p>@content.blockTitle</p> } } }
Hi Gilad, thanks for your help.
I tried to use the example razor from package page, but using CurrentPage didnt validate inside the macro and gave the following error.
"error CS0103: The name 'CurrentPage' does not exist in the current context"
@helper showFeatureBlocksReveal(dynamic widget){ if(!string.IsNullOrEmpty(widget.featureBlock.ToString())) { foreach (var content in CurrentPage.widget.featureBlock) { <p>@content.blockTitle</p> } } }
Using the following helper, I am given an error of
"Error loading MacroEngine script (file: RenderWidget.cshtml)"
@helper showFeatureBlocksReveal(dynamic widget){ if(!string.IsNullOrEmpty(widget.featureBlock.ToString())) { foreach (var content in widget.featureBlock) { <p>@content.blockTitle</p> } } }
When I remove the .blockTitle and leave just @content, the macro works, but outputs all the values of the grid data type.
Again, any help would be appreciated. Martin
Edit: Sorry im on the latest version of Umbraco installed through nuget
Can't Reference Individual Values - Razor Newbie
My razor macro is
Martin
Hi Martin.
