Hi is there an option to write values into the grid, like in the uComponents grid? Thanks
Hi, looking for the same functionality - did you work this one out?
Regards, L
I figured this one out - The data is simply saved as JSON. As such you can simply write JSON as the value. My solution was:
Create a class to model the properties (ensuring my attribute names matched the alias of the Content Grid property)
public class Foo { public string AliasName { get; set; } public string AliasName2 { get; set; } }
Created a JSON helper method to serialize the data
public static string ToJson(this object obj) { JavaScriptSerializer serializer = new JavaScriptSerializer(); return serializer.Serialize(obj); }
Set the value for your content
content.setValue("name", ToJson(new List
Hope that helps!
Hi thanks :) I will try it.
using the grid with a controller
Regards, L
Hope that helps!
Regards, L
