  • Craig100 1136 posts 2523 karma points c-trib
    Oct 08, 2014 @ 21:35
    Craig100
    Add Row issue 7.1.8
    Just added a simple content grid datatype. I set the max rows to 12. In the Page Editing Tab, the expected column headings appear correctly. However, clicking the "Add row" button causes a javascript alert to pop up saying the max rows are "-12". So I removed the requirement in the datatype so it should allow unlimited rows and tried again. This time nothing happened when I clicked "Add row".
    Please advise.
    Craig
    Oct 09, 2014 @ 02:29
    Craig100
    This is the Chrome Console output for when the "Add row" button is clicked. Give me the impression there's a dependency missing.
    TypeError: undefined is not a function at Object.$scope.addRow (http://localhost:53246/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…nUvQWN0aW9uTmV3UmVsYXRpb25UeXBlLmpzOw&t=Javascript&cdv=1714882888:1301:285) at http://localhost:53246/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…bnUvQWN0aW9uTmV3UmVsYXRpb25UeXBlLmpzOw&t=Javascript&cdv=1714882888:13:4671 at http://localhost:53246/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…lbnUvQWN0aW9uTmV3UmVsYXRpb25UeXBlLmpzOw&t=Javascript&cdv=1714882888:75:112 at Object.e.$eval (http://localhost:53246/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…bnUvQWN0aW9uTmV3UmVsYXRpb25UeXBlLmpzOw&t=Javascript&cdv=1714882888:14:7447) at Object.e.$apply (http://localhost:53246/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…bnUvQWN0aW9uTmV3UmVsYXRpb25UeXBlLmpzOw&t=Javascript&cdv=1714882888:14:7554) at HTMLButtonElement.
    Oct 11, 2014 @ 05:33
    Craig100
    Don't worry about answering this one, I switched to Archetype. Maybe you did to!
    Craig ;)
  • Andrew Bright 1 post 21 karma points
    Nov 18, 2014 @ 17:31
    Andrew Bright
    I have the same issue is there still no solution to this?
    Andrew :(
    Nov 18, 2014 @ 17:39
    Craig100
    Use Archetype ;) or maybe the Grid in 7.2 will sort this out.
