I created a little DataType with these fields: "Title" and "Text".
Then I add a new property to a DocumentType, with this DataType.
I create a new node of the DocumentType, but I look that the Grid does not works properly. I look only the label, a gray rectangle and "Add row" button.
Looking in Console of browser, i find this:
ReferenceError: index is not defined
at resetProertiesEditors (http://localhost:5555/Dependenc...
I found the issue in App_Plugins/u7dtg/u7dtg.controller.js, row 66:
// clean watchers before set again.
for (index = 0; index < propertiesEditorswatchers.length; ++index) {
propertiesEditorswatchers[index]();
To solve, you can replace these lines with this:
for (var index = 0; index < propertiesEditorswatchers.length; ++index) {
After the update, it is important to delete the ClientDependency folder in App_Data/Temp to clear the cache of ClientDependency.
Tiny issue in plugin: "index is not defined".
App_Plugins/u7dtg/u7dtg.controller.js, row 66:To solve, you can replace these lines with this:
ClientDependencyfolder inApp_Data/Tempto clear the cache of ClientDependency.Hi Flavio.
Thanks, it is fixed in current version 1.2
