Topic author was deleted
Hey, the create script doesn't work on sql ce, so it fails to create the table... and user forms start folder can't be stored
Hi Tim,
thanks for reporting the bug and we know it doesn't work with SQL CE. Sorry for that.
You could take a look at the source code and try to fix it yourself, but because we're not using SQL CE it's not on the top of our priority list. Sorry for that,
Jeffrey
Comment author was deleted
Ok no worries, wil just execute the create script manually
Doesn't work on sql ce
Hi Tim,
Jeffrey
