  • Markus Johansson 1945 posts 5899 karma points MVP 3x c-trib
    Mar 01, 2012 @ 09:22
    Markus Johansson
    CDN with S3 with Cloud Front?
    Hi!
    From what i know Amazon S3 is a great storage but i would like to use Cloud Front as well, as a CDN. Is there any provider for UMP that supports Cloud Front or is there another CDN that's currently supported?
  • Morten Christensen 596 posts 2773 karma points admin hq c-trib
    Mar 01, 2012 @ 14:11
    Morten Christensen
    Hi Markus,
    You can specify a custom domain (for CDN purposes) on the DataType when setting it up, but it still just looks in a S3 bucket for data. So if you have Cloud Front setup to use a specific bucket, you could select that bucket plus enter the domain name for Cloud Front on the DataType and it should work.
    - Morten
    Mar 01, 2012 @ 18:54
    Markus Johansson
    Sounds great! Have anyone done a successfull implementation of this? Is there any code that i can have a look at?
    Mar 01, 2012 @ 19:31
    Morten Christensen
    Just install the S3 provider ;) I know of a couple of people using it on a live site as is, so should work fine.
    As for the code I'll push it to bitbucket when I have some extra time to spare.
    - Morten
    Mar 01, 2012 @ 19:42
    Markus Johansson
    The S3 provider works great! I'm going to try to hook it up to cloud front as well. Thanks
