  • Fernando Garcia 4 posts 24 karma points
    Mar 05, 2012 @ 08:41
    Fernando Garcia
    Problems with UMP
    Hello.
    I'm trying to integrate UMP on a site i'm developing. Installed the last version of it (v1.5, directly from Umbraco backoffice) and a few providers for testing (Facebook, Flickr and Youtube).
    Then I did all the required setup (post installation):
    • Added new data type
    • Authenticated account
    • Added new property to document type (of new data type)
    • Activated the sample macro ([UMP] Facebook Example) visibility in the RTE.
    • Edited content page and choosed media item for the previous property (the picker perfectly showed all the available items in the account)
    • Added the macro directly on the main page content markup (RTE).
    It didn't worked. Just showed "Error parsing XSLT file: \xslt\[UMP]FacebookExample.xslt" on the rendered html.
    I setup a new macro for testing (visualize) on the XSLT editor, but it returned the next error (I'm translating it from spanish):
    Error parsing the XSLT:
    System.Xml.Xsl.XslTransformException: Can't find any script or extension object associated with the namespace 'urn:facebook'. in System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args) in (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime) in Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime) in System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer) in System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results) in umbraco.macro.GetXsltTransformResult(XmlDocument macroXML, XslCompiledTransform xslt, Dictionary`2 parameters) in umbraco.presentation.umbraco.developer.Xslt.xsltVisualize.visualizeDo_Click(Object sender, EventArgs e)}
    I'm suspecting than the installation went wrong, but just can't figure out where to start checking: the Flickr provider also generated an error (ASP.NET exception): Access to the path 'FlickrNet' is denied (which somebody else has posted here).
    Any ideas about these problems??
    Thanks in advance.
    Mar 05, 2012 @ 21:00
    Fernando Garcia
    I just installed the package/providers on a fresh umbraco installation and got the same error. I suppose the errors are in the providers, because this time I also installed the Picasa provider and it worked just fine.
    Btw: My setup is: Windows Server 2008 R2 (IIS 7.5), SQL Server 2008 R2 Express, and VS 2010 (non related right now).
  • Morten Christensen 596 posts 2773 karma points admin hq c-trib
    Mar 31, 2012 @ 15:19
    Morten Christensen
    Hi Fernando,
    Sorry about the late reply.
    With regards to the facebook provider please make sure this extension is added to the xsltExtensions.config file:
      <ext assembly="Sitereactor.FacebookMediaPicker" type="Sitereactor.FacebookMediaPicker.FacebookXsltExtension" alias="facebook">
    </ext>
    The error with the FlickrNet provider sounds like its related to web.config configuration. During installation a couple of elements should be added in order for the Flickr provider to work. If you look for the following lines in your web.config:
    <configSections>
    <!-- standard umbraco web.config configsections would appear before the flickrNet section -->
    <section name="flickrNet" type="FlickrNet.FlickrConfigurationManager,FlickrNet" />
    </configSections>
    <flickrNet cacheDisabled="true" />
    - Morten
    Apr 12, 2012 @ 04:49
    Fernando Garcia
    Hi Morten, thanks for the reply.
    I'll check those tips as soon as I can. For now we're using the Picasa option to upload and link images in our Umbraco installation, but we're still interested (at least) in using the Facebook provider too.
    Fernando.
