  • andrew shearer 513 posts 663 karma points
    Oct 31, 2013 @ 23:52
    andrew shearer
    problem syncing doctype modifications?
    hi
    using usitebuilderadmin 2.1.2beta and umbraco 6.1.6, it seems that new doctype changes are applied successfully, but modifications to existing doctypes aren't? For example, an update to a property description isn't applied.
    has anyone else experienced this?
    thanks
    Nov 01, 2013 @ 01:29
    andrew shearer
    NB the panel indicates the doctype has been modified, its just that clicking the 'sync' button doesn't actually apply the changes.
